ACE Pipe Replace, don't know which line is which
Old Sep 6, 2021 | 08:14 PM
jakeair's Avatar
5th Gear
Default ACE Pipe Replace, don't know which line is which
OK guys, I screwed up, removed my rear ACE lines from the control valve block (because of a leak in the flex line) and went to a hyd shop and they made me up some new lines ($237.00), the problem is I did not take pictures of which line goes where. I have found a drawing online (see below), and it shows the High pressure line is the top pipe coming out of the forward side of the control valve block. My question is, which side of the rear actuator does the high pressure line connect to?......The Piston side?, like in the drawing below? big lesson here, take pictures!!
Old Sep 7, 2021 | 07:46 AM
frostythor's Avatar
read this, copy and paste it in google then go down the page to find the info your looking for, its from the UK landyzone post
https://www.landyzone.co.uk/land-rov...ematic.341764/
Old Sep 7, 2021 | 08:11 AM
jakeair's Avatar
5th Gear
Thanks frostythor, so the banjo fittings are orientated to the actuator in the diagram ?
Old Sep 7, 2021 | 08:13 AM
jakeair's Avatar
5th Gear
Old Sep 7, 2021 | 08:24 AM
frostythor's Avatar
Sorry not my post I just found it as that was inline with what your looking for
Old Sep 7, 2021 | 09:19 PM
jakeair's Avatar
5th Gear
Thanks, that did help, got my Disco going again.
Old May 9, 2023 | 07:18 PM
tonyymex's Avatar
Hi guys Im from mexico I have a 2006 range rover L320, I need urgently your help I removed the pipes from my ACE BLOQUE and I lost the sequence in which is wich in the valve bloque Im talking about the pipes from the front stabilizer ace bar, can some body tell me or send a drawing of the sequence please
tobinmakayla@gmail.com
May 14, 2020 02:57 AM
Best4x4
Sep 17, 2018 05:31 PM
difrentbob
Apr 12, 2016 03:32 PM
captain203
Dec 18, 2013 06:41 AM
Dane!
Nov 8, 2013 02:11 PM
