OK guys, I screwed up, removed my rear ACE lines from the control valve block (because of a leak in the flex line) and went to a hyd shop and they made me up some new lines ($237.00), the problem is I did not take pictures of which line goes where. I have found a drawing online (see below), and it shows the High pressure line is the top pipe coming out of the forward side of the control valve block. My question is, which side of the rear actuator does the high pressure line connect to?......The Piston side?, like in the drawing below? big lesson here, take pictures!!
Hi guys Im from mexico I have a 2006 range rover L320, I need urgently your help I removed the pipes from my ACE BLOQUE and I lost the sequence in which is wich in the valve bloque Im talking about the pipes from the front stabilizer ace bar, can some body tell me or send a drawing of the sequence please
