Added DRL to my '01 D2
Old Feb 2, 2017 | 09:47 PM
Rover_Hokie's Avatar
Default Added DRL to my '01 D2
I bought a DRL kit on ebay for approx $15-$20 that has wiring and a small box inline. I cut the hot lead behind each of the small "city lights" in the head light housing of '99-'02 model D2's and used the wiring kit to wire the hot leads using the wiring assembly in the kit with the inline box with a positive & negative wire coming off the other end of the box going to the matching battery post. That's it. The little inline box which I presume is a relay and/or diode allows the power to flow to the lights when the battery voltage is > 13.5 volts which is when the alternator is charging, i.e. when the engine is running.
Neb
Jul 27, 2020 04:17 PM
Rover_Hokie
May 29, 2013 06:14 PM
longjon76
Oct 3, 2011 06:31 PM
AuZZZie
Sep 1, 2011 11:50 AM
Dan_da_LR3_H2_man
Nov 10, 2008 12:31 AM
