Adding 12v power ports
Old Apr 24, 2015 | 08:49 AM
  #21
lighting's Avatar
I will run a separate fee line from the fuse box, hence a relay and separate dedicated fuse. Just me, I know there is not need but you can never be too safe in a electric circuit, extra layer of safety that's all but in reality a 20 amp fuse will be plenty protection for a low draw circuit like this
Old Apr 24, 2015 | 09:39 AM
  #22
abran's Avatar
Paul in the UK sells 2 connectors that fit the 2 unused ports on the interior fuse box.
Here is his email.
lr_connectors@btinternet.com
Old Apr 24, 2015 | 09:43 AM
  #23
drowssap's Avatar
most auto parts store sell these tap a line fuses
20A Regular Blade Fuse Tap Holder Add A Circuit Line ATO ATC Apr Car Truck | eBay
Old Apr 24, 2015 | 10:26 AM
  #24
abran's Avatar
Here are pics of Paul's connectors. He also gives you the breakdown of what wires are what.
This is for S12:
The circuits are as follows -
Terminal-5 - Live - ignition switched (position 1 on ignition switch), via fuse F27 (10 Amps)
Terminal-4 - Live - permanent, via fuse F20 (15 Amps)
Terminal-3 - Live - switched, from auxiliary circuits relay, via fuse F15 (20 Amps)
Terminal-2 - Live - from main lighting switch (sidelights position), via fuse F33 (10 Amps)
Terminal-1 - Earth - via C0583 to C0017-1 (Earth Header) on 3.0mm² cable
Attached Thumbnails Adding 12v power ports-image008.jpg   Adding 12v power ports-image009.jpg   Adding 12v power ports-image011.jpg   Adding 12v power ports-image013.jpg
Old May 31, 2015 | 04:39 PM
  #25
Joemamma1954's Avatar
I followed fishEH's install, but only put in the double usb port, since the stock one is real close. I also went with the connectors that abran posted about from Paul. The whole thing took 15 minutes. I also used the 15 amp pin, that is live at all times, since the stock one is switched.
bearskinrug
Jun 30, 2014 09:43 PM
keoni004
May 29, 2013 08:41 PM
thearmlesswonder
May 2, 2013 10:00 PM
newBrover
Jul 25, 2010 04:57 PM
DiscoWest
Mar 15, 2010 11:24 AM
