Advice on rebuilding front drive-shaft with greaseable u-joints
Old Aug 17, 2009 | 11:53 AM
  #41
ccombrink's Avatar
Originally Posted by bangkuaidiscovery04
Wow I went to the local import mechanic and he gave me an estimate of at least $250 for the whole job!! Now I feel like I would have been hustled if I would have left my Disco there. Anything under $200 was going to be a good price for me. Too bad I'm not mechanically inclined or the job would be under $100.
Wow I wish I had a shop locally that was nice. The local shop out here quoted 475 for parts, removal, rebuild, and reinstall. I thought that was way to high. I found a local car guy that works on these for fun and he did it for 100 plus parts. (I had to get someone to do it due to stripped nuts. Have to thank Land Rover for that one.) I ordered my parts from Todd Co Suspension ( http://www.toddcosuspensions.com/diiifrdrovki.html ). They are the OEM Manf but they are the HD variation with zerks in the end caps. It came with the centering ball/seal, and 3 HD u-joints.
Though I have to thank everyone on here for the warnings of the driveshaft woes. I almost had mine fall out. It was missing two end caps on one u joint and they where worn almost down to nothing.
Old Aug 17, 2009 | 12:33 PM
  #42
antichrist's Avatar
I'm curious, what was the mfg name on the boxes, and what were the part numbers?
Old Aug 17, 2009 | 03:17 PM
  #43
ljdiscovery's Avatar
I noted on the Toddco website that they sell a variety of Land Rover products. They even have a sale going right now (no affiliation). The front driveshaft rebuild kit is just $99, lower than buying here in San Diego, Carquest price about $135 plus tax for Neapco parts. A rebuilt front driveshaft with greaseable zerks, etc. is just $279, plus a $60 core and shipping. At that price, it seems hardly worth trying to rebuild the old one. I do not know what kind of warranty they offer. Phil
Old Aug 21, 2009 | 07:47 PM
  #44
Disco2inferno's Avatar
Default DIsco Mike! Can I get the Drive shaft rebuild PDF?
Please! Mines goin quick. Please send it to jamesmcgee77@gmail.com Thank you so much.
Old Aug 21, 2009 | 08:41 PM
  #45
antichrist's Avatar
Default Correct PDF to use
http://www.box.net/shared/jbgsi67tnx...9364:131879309
You should read this post as well, not sure the corrections to the pdf have been made.
http://www.discoweb.org/forums/showp...0&postcount=16
Old Aug 22, 2009 | 09:02 AM
  #46
jefsantiago's Avatar
Default Drive shaft rebuild
Originally Posted by Disco Mike
If you are fairly mechanical, I have a PDF that can go step by step thru this, including replacing the center ball also.
What year is your truck and how many miles on it?
Send me your e-mail address for the PDF.
Do you have this document for 97 Discovery? If you do, kindly send it to jefsantiago@ielogistics.net. Thanks in advance.
Old Aug 22, 2009 | 11:59 AM
  #47
antichrist's Avatar
A '97 would be the same as a DII, just use the procedure for the single cardan end on both ends.
Alternatively, you can follow the steps in the factory shop manual.
Old Aug 25, 2009 | 09:58 AM
  #48
antichrist's Avatar
Originally Posted by jycsalas
i dont know if this is the same one but here it is
http://static.scribd.com/docs/tkatf9...IAL_VIEW=width
I finally got around to looking at this link and just wanted to say it shouldn't be used for directions. It's an early draft of the one I posted a link to, but this version has several errors including incorrect part numbers.
greenwade
May 5, 2010 07:47 AM
nervous4ever
May 10, 2009 09:00 PM
DISCOLUV
Mar 13, 2009 08:54 PM
roadshadowww
Jan 15, 2009 08:44 PM
javoli001
Apr 30, 2008 08:28 PM
