Aftermarket bumper affect temps?
Old Aug 7, 2012 | 04:40 PM
  #21
ebg18t's Avatar
Dumb question: I want to verify that the fan was reinstalling going the right direction when they put it back together. How would I verify it?
Old Aug 7, 2012 | 05:09 PM
  #22
cupped side of blades toward block. When running, fan should hold a paper towel or wimpy plastic bag to the grille, not blow it away. Ditto for electric fans.
My PO had belt on wrong, and electric fans wired polarity revesed, so lots of things ran bass acwards.
Old Oct 9, 2012 | 01:36 AM
  #23
Rover_Hokie's Avatar
Last spring I had my water pump replaced by a shop while replacing the timing cover gasket. Water pump died shortly after as it began leaking from the weep hole. I noticed when replacing the water pump myself to fix it, that the belt had been routed over the water pump pulley rather than under it as it should have been. Lesson learned, never back to that shop even though it was recommended by another D2 owner. Will always check the belt routing after anyone else touches it in the future.
Old Oct 9, 2012 | 06:40 AM
  #24
When I bought my "Frankenstein" - (brought back to life with parts from the dead ones) - the PO had belt route wrong, bad fan clutch, electric fans hooked up reverse polarity, and was missing the top of the radiator fan shroud. All bad by themselves, and combined were "hot stuff."
IMHO a small photo copy of the belt route, under clear plastic shipping tape, would be a plus under the hood.
jamieb
Jun 29, 2014 06:16 AM
LRchick
Apr 30, 2013 02:32 PM
CANAMDiscovery
Apr 2, 2012 04:20 PM
AxeAngel
Jan 16, 2008 01:40 AM
pilsner
Jan 15, 2008 01:04 PM
