aftermarket coolant gauge question
#21
Also I was under the impression that the whole point of raising the reservoir for bleeding purposes is for the purpose of making the bleeding screw the lower point, am I missing anything?
#22
#23
just got the glowshift gauge in the mail today. was reading threw the instructions and it talks about T connection ( which i got the 32mm one) or a plug on the block. so now im thinking it would be pretty easy to get the sensor threaded in place of driver side drain plug. is this what the instructions are referring to? or is there another "coolant fluid port" on the block i don't know about? instructions also says the coolant port needs to be threaded in 1/8 NPT. is the drain plug that thread?
#24
You could give it a try and it would be a very good option for others to know about if it works. Unless you hear otherwise doubt few if any have tried before as adverse folks seem to be to removing the plugs during normal drain/flush.
#25
when i looked at the glowshift sensor, i was wondering the same thing number9.
ill just stick to installing it on the upper hose for now to reduce the loss of coolant while doing the install. next time i go to drain the block ill test out and see if the sensor goes in fine without hitting anything.
the rep from glowshift told me that the OEM sensor with the two wires coming off it will not work on the glowshift water temp gauge. i guess different resistance readings.
atancreti
10-03-2011 04:44 PM
