all kinds of problems.
i have a '96 disco. and had recently found that the v.s.s. is the one cause of my problem. so until i can get my new sensor, i have disconnected it to get to and from work. but at random times the e-brake light will come on and off, and more importantly during quick braking the tach will drop down to near 100 rpm. a couple of times it has stalled out. the radio keeps right on like a champ, but my headlights will dim. is the disconnected v.s.s to blame? Any help would be greatly appreciated. Thanks.
Jared
Jared
RE: all kinds of problems.
ORIGINAL: jared
thanks for the advice i will definitely check that out. do you have any ideas as far as the e-brake light goes? it comes on sporadically. no real harm in it just annoying at night when i can see it better. thanks again for the help.
mark this can make the brake light come on.
ok, well the search continues. i had my battery/alternator tested. they said the battery was bad, and i swapped that out, the alternator checked out good. but it is still doing the same thing. if i can stop very smoothly i can shift into neutral and stop hard at the end and be alright, but if i just emediately shift into neutral as i began to slow down, it will just stall out.
DiscoRover007
07-14-2020 12:54 PM
adventure95004
05-09-2019 11:51 AM
00&04 Disco
09-07-2013 01:46 AM
thearmlesswonder
05-02-2013 10:00 PM
