all kinds of problems.
Old Dec 13, 2007 | 05:51 PM
jared's Avatar
Default all kinds of problems.
i have a '96 disco. and had recently found that the v.s.s. is the one cause of my problem. so until i can get my new sensor, i have disconnected it to get to and from work. but at random times the e-brake light will come on and off, and more importantly during quick braking the tach will drop down to near 100 rpm. a couple of times it has stalled out. the radio keeps right on like a champ, but my headlights will dim. is the disconnected v.s.s to blame? Any help would be greatly appreciated. Thanks.
Jared
Old Dec 13, 2007 | 07:06 PM
Default RE: all kinds of problems.
Go clean and tighten your battery cables then go to your local auto parts store and have a free battery/alternator test run, you'll find your problem.
Old Dec 13, 2007 | 08:56 PM
jared's Avatar
thanks for the advice i will definitely check that out. do you have any ideas as far as the e-brake light goes? it comes on sporadically. no real harm in it just annoying at night when i can see it better. thanks again for the help.
Old Dec 14, 2007 | 06:46 AM
Landzu's Avatar
ORIGINAL: jared
Check your brake fluid level it maybe just at the add
mark this can make the brake light come on.
Old Dec 14, 2007 | 07:39 AM
Adjust the e-brake cable and that will take care of the light.
Old Dec 14, 2007 | 06:35 PM
jared's Avatar
thanks for the advice guys. i will check those out. i also had my battery/alternator tested and it was a bad battery. i appreciate that mike.
Old Dec 17, 2007 | 09:03 AM
jared's Avatar
ok, well the search continues. i had my battery/alternator tested. they said the battery was bad, and i swapped that out, the alternator checked out good. but it is still doing the same thing. if i can stop very smoothly i can shift into neutral and stop hard at the end and be alright, but if i just emediately shift into neutral as i began to slow down, it will just stall out.
Old Dec 17, 2007 | 03:25 PM
grrRover's Avatar
Yo I am having somthing simualr with the electrical and had all mine test and they said everything was fine and it died on me this weekend it is a96 as well
Old Dec 17, 2007 | 05:59 PM
jared's Avatar
let me know if you figure out what it is. and ill keep working on it as well. appreciate it.
DiscoRover007
Jul 14, 2020 12:54 PM
adventure95004
May 9, 2019 11:51 AM
00&04 Disco
Sep 7, 2013 01:46 AM
thearmlesswonder
May 2, 2013 10:00 PM
polargirl0000
Aug 8, 2010 11:45 AM
