All TC lights on
Old Feb 1, 2007 | 11:57 PM
EEDEF's Avatar
Default All TC lights on
I have a problem. 01 Disco II SE, TC lights on, no mech problems. Dealer tells me the computer needs to be reset continuously, could this be an electrical problem (i.e. fuse). All systems seem to work fine. Any suggestions that won't cost an arm and a leg.
Thanks
Old Feb 2, 2007 | 10:14 AM
Default RE: All TC lights on
You will need to have someone scan the system, check the codes, turn them off and go drive some more. Sme times the lights come on for no obvious reason, if they come back on have to recheck for codes to see what is causing the problem.
Usually it is a dirty wheel sensor that may have been knocked loose, or cheap after market brake pads that are dusty and squeak alot.
Mike
DiscoRover007
Jul 14, 2020 12:54 PM
adventure95004
May 9, 2019 11:51 AM
polargirl0000
Aug 8, 2010 11:45 AM
USMC_Denver
May 8, 2009 12:41 PM
