Alternative ideas to engage cdl?
Old Jan 3, 2015 | 12:01 PM
  #21
Stoa guy's Avatar
6th Gear
Why not use the electric actuator and cable system OX uses for there diff lockers. Very similar throw, electric ( so no air to worry about) waterproof, just add a switch to the interior and Boom!
Electric Actuated Shifter - OX USA
Old Jan 3, 2015 | 01:06 PM
  #22
94svt50's Avatar
That would be too easy, Its a land rover why use one part when you can use 17.
Good idea Im going to look into this.
Old Jan 3, 2015 | 01:47 PM
  #23
Stoa guy's Avatar
6th Gear
Well sorry about that man ;-) I registered for the site yesterday and that was my first post! I'll try to keep the reasonable ideas to a minimum
Old Jan 3, 2015 | 01:51 PM
  #24
Stoa guy's Avatar
6th Gear
I have ox lockers front and rear in my jeep Cherokee, The electronic actuators works phenomenally, i've had them installed for two years and I can't tell you how many times it's been fully submerged and caked with mud and abused. Also because the switch is backlit and the way that ox wires the switch for you it only aluminates once it's fully engaged showing that the action is taking place. I'm thinking you would need those 17 extra pieces to do that with air :-)
Old Jan 3, 2015 | 01:58 PM
  #25
94svt50's Avatar
Do you think the actuator would have enough force to move the shift lever? It does take a small amount of effort to turn on the diff lock. And welcome to the board.
Old Jan 3, 2015 | 02:38 PM
  #26
Stoa guy's Avatar
6th Gear
I have no idea what the actual measured output of the actuator is but I have no doubt that it could move it check out the video on ox's website of what it actually does, it pushes a shift fork inside my front and rear differential sliding over a collar that engages teeth to disallow differentiation. The collar in the differential is loaded with numerous heavy Springs, i'm guessing the load is pretty equal
Old Jan 3, 2015 | 02:40 PM
  #27
Stoa guy's Avatar
6th Gear
If someone knows where I can locate a transfer case to work off of maybe I'll build the system for you guys.
Old Jan 3, 2015 | 05:14 PM
  #28
94svt50's Avatar
Well the ford ranger shifter motor is out. Spent the day designing the electrical hook up for it to utilize its built in position sensor, it would take a series of about 20 relays. Basically have to make a digital system into a an analog system of switches, not practical not reliable.
Old Jan 4, 2015 | 03:43 AM
  #29
abran's Avatar
I have one in So Cal. Where are you?
Old Jan 4, 2015 | 03:21 PM
  #30
My diff lock nipple turned with almost no effort, I was really surprised.
Spencerfitch
Oct 24, 2013 07:45 AM
unstable
Apr 29, 2008 07:15 PM
02Disc02
Apr 22, 2008 10:09 AM
R_Lefebvre
Jan 23, 2008 07:49 PM
jkid
Oct 20, 2007 09:33 PM
