Alternator Bracket Bolt Source?
Old May 15, 2018 | 05:38 PM
CollieRover's Avatar
According to 10 + sources that bolt size is correct.....BUT....I'm with you
If you are finding the info on the site(s) for fb110201L listed wrong then the best bet is to go to HD, Local Hardware Store, or even a NAPA to match the bolt size. Get at least a grade 8.
Thanks. I will have to see what I can find.
Old May 15, 2018 | 05:57 PM
Alex_M's Avatar
If you have something to cut metal with, thread a nut on to the bolt. Cut it, file the end, then remove the nut which will clean the threads.
Should probably cost you $3 at the hardware store.
Old May 15, 2018 | 09:56 PM
great idea. I found a 3.5” 3/8” Grade 8 bolt and with a washer it is within a mm or so. I will see how that goes. The 4.0” was a bit too long for my liking.
I usually am in the drawers, so I was opened up to a whole new world when I turned around. I’t’s not flanged but that’s fine with me.
Thanks for all the advice guys.
Old May 15, 2018 | 10:20 PM
Okay. While obsessing over the possiblity of another bolt breaking I found these stainless steel ARP bolts that should work.
https://arp-bolts.mobi/?src=redirect...?RecordID=2594
Ordered them up, torque value is well past the 30ft lbs for Alternator bracket.
Old May 15, 2018 | 10:24 PM
I’ve got a dumb question related to my bolt issues. I haven’t been using anti seize/grease in bolts unless a sealant is called for.
Should I use a dab of grease on bolts?
Old May 15, 2018 | 10:50 PM
OverRover's Avatar
I'm a big fan of anti-seize and have been for well over 35+ years. The problem most people have is using too much!
Just swipe the brush on one side of the fastener and let the anti seize work its way around the threads...simple.
This is my go to, or others made by Permatex or Loctite (depends on application)
> https://www.permatex.com/products/lu...e-lubricant-2/
Old May 16, 2018 | 06:29 AM
I have it and have used it, but as you mentioned I used way too much and got sick of the mess.I am going to start using it properly.
doomed
Jan 19, 2024 10:15 AM
JettsRover
May 22, 2019 05:10 PM
w7412r
May 26, 2010 12:36 AM
my89rangerover
Sep 1, 2009 11:33 PM
SmyLeOrElse
Apr 9, 2007 10:00 AM
