Alternator Going Bad?
Old Sep 19, 2009 | 06:00 PM
  #21
Originally Posted by Carl082974
The used alternator arrived today, it is in good condition.
But I ordered a 2001 alternator and they sent me a 2000 one.
I think it should be ok because the same part# was used for both 2000 & '01.
Can someone confirm this???
You are fine, all DII,s use the same alternator.
Not sure if the DI and DII use the same one or not though, but yes, you are perfectly fine.
Old Dec 13, 2009 | 01:39 AM
  #22
JumPeR04's Avatar
My alternator went out a wk ago so I had to go get a used one and got it testing before I put it on and I made sure that All cables and wires were tight but it still want to act like it doesn't want hold a charge lights dims and starts wanting to died on me so I don't know if the belt is bad or what
Old Dec 13, 2009 | 06:35 AM
  #23
Mrmerlin's Avatar
get a multi meter and check for charge at the battery if its lower than 13.4 then the battery will not get a full charge . A good charge system will run from 13.5 to 14.5 at about 1500rpm
Old Dec 13, 2009 | 08:17 AM
  #24
JumPeR04's Avatar
I brought a new battery like two wks ago but I will try that
Old Dec 13, 2009 | 12:56 PM
  #25
JumPeR04's Avatar
Ok had the battery test and it is good but belt is still want to whine and so do you hits thinks I should chang out the belt
Old Dec 13, 2009 | 07:00 PM
  #26
JumPeR04's Avatar
I just change the belt and everything is good but the rpm are beyond 1 idle and half way between 1 and 2 when I hit 50 mph
TATZOO
Jun 10, 2013 05:22 PM
Exclusivelyme480
May 1, 2011 01:28 PM
edh
Jan 21, 2010 05:42 PM
mgabriel
Dec 11, 2008 11:53 PM
mathis_m1a1
Jan 9, 2007 05:11 PM
