alternator rebuild kit
Old May 19, 2009 | 11:36 AM
barrylee66's Avatar
Default alternator rebuild kit
I just bought a 01 discovery ll and have been giving it some tlc and noticed the alternator making noise. when I replaced the belt I spun the alternator and it is making the noise. my question is does anyone know where to get alt rebuild kit? I went napa and they said they did not have it. I looked on e bay and did not see it either
Old May 19, 2009 | 11:46 AM
okdiscoguy's Avatar
go to the general tech tab. There is a stick of good suppliers for Rover parts. I don't know off the top of my head. I have seen posts from people having problems after rebuilding. I would suggest replacing.
Old May 19, 2009 | 03:05 PM
www.autosportsunlimited.com will sell you a good used one for ~$70, or AutoZone will sell you a reman for $180.
Old May 19, 2009 | 05:25 PM
Stay away from AutoZone, I saw one persong that went thru 4 or 5 of their alternators in a little over a week.
Old May 19, 2009 | 05:26 PM
There are no "KITs" available, probably find a bearing, have you ever tackled an alternator before.
Old May 20, 2009 | 12:52 AM
mordor110's Avatar
Yes agree on the AutoZone rebuilt stuff. I had one in my Acura a few years back and it only lasted a year before the bearing had a melt down.
Maybe you can search for a shop in your area that specializes in rebuilding starters & Alt's etc. I took my Disco Alt to a local one that I've been using for years & they do a great job. Sometimes it's just the brushes and they'll sell me those for $8!
If you're experienced with taking the alt apart and have the pullers etc you can get the bearing out and there should be a number on the side of the race you can use that to find a new one. Try SKF or KYG?
Old May 21, 2009 | 02:55 PM
barrylee66's Avatar
I took it apart and napa has the small bearing but can not find the front large bearing even by crossing the numbers and measuring it. and the rebuilt one I see at autozone is 250 unless I am missing something. and yes I can rebuild an alternator and have the tools pullers press and big hammer.
Old May 21, 2009 | 03:12 PM
Jawbox's Avatar
No idea where you are from, but most decent sized towns have bearing shops that can take care of that. Take a look in the yellow pages and stop in.
Old May 22, 2009 | 09:43 PM
jeffzx9r's Avatar
Depending on what alternator you're running (i.e. fixing) you may be hurting yourself if you turn it in as a "core." It may be worth more than the re-man that works!
FlyingZebra34
Jul 31, 2013 06:00 AM
zukijames
Nov 16, 2012 12:13 AM
SolbergFanBoi
Dec 23, 2011 08:57 AM
coloboy
Feb 2, 2011 05:43 PM
Spike555
Jun 21, 2010 07:27 PM
