Alu coolant header tank
Old Aug 1, 2015 | 02:01 PM
OffroadFrance's Avatar
Default Alu coolant header tank
Hi
Your splitting header tank troubles are over .................. if you are rich or desperate. Admittedly it's for a TD5 Defender but I'm sure with ingenuity it could be fitted to a D2.
Aluminium header tank
Old Aug 1, 2015 | 03:41 PM
cappedup's Avatar
Imagine having to take the cap off every time to check the level.
Old Aug 2, 2015 | 06:05 AM
Hi cappedup,
That little detail did cross my mind also . Fortunately in 13 years I have never needed to replace my reservoir or the pressure cap but on the forum here I've read that so many seem to run into difficulties with the reservoir splitting and the cap causing prolems.
Old Aug 3, 2015 | 07:38 PM
Charlie_V's Avatar
I've had mine 16 years but I live in fear of the next malfunction. So, what causes them to Crack? Cold (no worries) or heat (eek!)?
Old Aug 4, 2015 | 05:25 AM
I think, like most things plastic, it's part luck, part heat and part vibration. The alu tank would be far better if it had a sight glass so avoiding the need to remove the cap to check the level.
aguison
Nov 16, 2012 09:29 AM
meltdowndave
May 23, 2008 12:49 PM
ajh
Sep 30, 2007 08:50 AM
97discoI
Aug 19, 2007 09:49 PM
