Am I getting screwed?
Old May 7, 2012 | 07:19 AM
  #21
tdorland's Avatar
Originally Posted by RoverMasterTech
I hate reading these posts with unwarranted animosity towards repair shops... Be it a stealership or an indy, we have to make money to continue to provide you with a service. First off you have a line by line estimate of all repairs getting done, you can judge for yourself weather its fair or not. If you don't have a line by line estimate, drive away.
Second: Don't cry when they charge you 100 bucks to spend 3 man hours diagnosing, calling for prices, writing an estimate, calling you, then closing out paperwork.
Third: Don't buy your own parts. I buy my parts at a 20% discount of what you can get them for, then I mark them up 20% and charge you. So instead of the part supplier getting the 20% I do. If you bring your own parts, I wont warrantee my labor if the part you bring should fail. And if you think you are getting a bargain, you are wrong, if someone gives you a price of 1000 bucks for head gaskets, you are getting 1000 bucks worth, no cleaning, no checking for true, no machine work, no valve job, they just pop the heads off and put a new gasket in and put the heads back on. You can end up like the guy I had in my shop the other day, screaming about how he just had the head gaskets replaced 5000 miles ago at "we be fixin your car, auto repair" and now his car needs head gaskets again. But hey he got a great deal! 1000 bucks out the door!
I don't have any problem with what they're charging me. I just don't know what is a fair price. That's all. If 2800 is the going rate, I don't have a problem paying it. He also warranties all the work for 1 yr and 12K, so if I have another leak for some reason, I can go back there.
Like I stated in the original post, I want to keep the truck, so I'd rather have the job done right then just a quick fix.
Old May 7, 2012 | 08:02 AM
  #22
SO, you decided to not talk with me regarding your options, too bad for you, could save you Hundreds.
As for what is a fair price, most shops follow one of the shop rate manuals which sets an hourly rate for each job. In the case of a D2, with SAI, it is under 12 hours plus possible sublet head inspection/repair. This being the case and since parts will be less then $300 where do these high charging shops get away with a $2500 labor bill??
Just a thought from someone who was in the business for nearly 30 years.
Old May 7, 2012 | 09:07 AM
  #23
jafir's Avatar
Originally Posted by Disco Mike
[snip]where do these high charging shops get away with a $2500 labor bill??
At the shop I worked at we DID charge a premium for the European cars that didn't have a local dealership in the area. This was mainly to cover the cost of the diagnostic equipment and the extra effort and price of sourcing parts. I think we added 10 to 20 percent to the labor rate depending on how high-end the make was. I know Jaguar and Land Rover certainly got the higher rate because the closest dealer was 2 hours away. BMW got normal prices because the dealer was in town, their parts were cheap, and the dealer actually sent customers with "older" cars to us because they were too busy to mess with the old stuff.
Still, charging what seems to be DOUBLE is hard to justify. I wonder if they are charging full dealer list price on the parts. Some dealers mark their parts up WAY over MSRP. When I had a D1, I remember calling that two-hour-away rover dealer for an oil pressure switch. You know the one that is part of a TSB so the price is only like $7. They wanted $24 or something stupid.
Old May 7, 2012 | 09:09 AM
  #24
Another member posted about a $900+ CKP sensor repalcement in the past week or so.
Old May 7, 2012 | 09:58 AM
  #25
jafir's Avatar
Lol. Maybe it came attached to a low mileage block.
Old May 7, 2012 | 10:20 AM
  #26
RoverMasterTech's Avatar
My price would go like this, 12 hours to R+I heads and check for true, block and heads. 4 Hours to remove all the valves, clean all the valves, combustion chambers, check guide clearance re-lap valves in. $200 to reface valves/plane heads. You would get new lifters. 4 Hours to R+I front cover, you would get new oil pan gasket, crank seal, crusifix seals (on rear main cap) Oil pump gears, and o-rings for cam sensor and oil cooler hoses (if applicable) Then your looking at 800 bucks in parts. $2580 is what I came up with, 2750 is what I would quote you with tax. So you are right in the range.
Old May 7, 2012 | 10:29 AM
  #27
DiscoRover007's Avatar
I mean I guess the upside to paying $2800 is that you shouldn't have any engine related troubles for a long time, if you maintain it well. You get a lot of work done for that price.
Old May 7, 2012 | 10:37 AM
  #28
A pro knows what can be done on same trip, and whAt may be at end of service life. It is not overkill, it is saving money on future repair.
Robover01
Nov 23, 2009 08:48 PM
jarkalina
Oct 31, 2009 08:15 PM
Speed racer
Nov 1, 2008 12:38 AM
Speed racer
Oct 30, 2008 11:29 PM
Erik
Jun 17, 2007 11:59 AM
