Amber Service Engine Soon light
Old Aug 28, 2012 | 11:03 PM
Joshman's Avatar
Code came back as P0441 - Evap control system incorrect purge flow. No idea what this means.
I have the rave manual, but I must be using it wrong. There are a bunch of PDFs in a zipped folder that all have garbled names. Maybe that is the only way it works.
I will start googling and see what I am looking at. If any of you have an idea, I'd be grateful to hear it. Thanks.
Old Aug 28, 2012 | 11:13 PM
Joshman's Avatar
My brother in law said that the p0441 code sometimes comes if the gas cap isn't clicked on tightly, and I saw that DiscoMike has said that the gas cap is the source of that code 90% of the time. I had the code reset and I will re-tighten the cap. Let's see if that works. Thanks guys.
So, any takers on telling me your advice on the spark plug wires?
Old Aug 28, 2012 | 11:41 PM
willrok13's Avatar
Gas cap. It happens to me quite a bit. I will be changing it out soon.
Old Aug 28, 2012 | 11:42 PM
FLDiscoII's Avatar
The stock plug wires are junk. You'll definitely want to upgrade to a good 8mm silicone wire. You'll see a lot of guys using either Magnecor or STI, but Kingsborne are also a good option.
Old Aug 28, 2012 | 11:43 PM
willrok13's Avatar
Try downloading Rave from landroverresource.com. It should give you a single PDF file that will work.
Old Aug 29, 2012 | 06:59 PM
Discovery_Scott's Avatar
I had that code come up a few times, for me it was just the gas cap... I bought a new one and never saw that code again.
As far as wires go, I went with the 9mm Magnecor wires, bought them a year ago, but just put them on a week ago
Old Oct 22, 2013 | 05:12 PM
Joshman's Avatar
Does anyone here recommend a non-lanyard tied aftermarket gas cap? They can be had for like $8 as opposed to $35 or so for the original replacement from AB.
Is it possible to just replace the rubber o-ring instead of the whole cap?
Old Oct 22, 2013 | 05:52 PM
bballjames's Avatar
Just buy one off amazon. Way cheaper and does the job fine.
Amazon.com: Motorad MGC-817 Fuel Cap: Automotive Amazon.com: Motorad MGC-817 Fuel Cap: Automotive
Old Oct 22, 2013 | 10:48 PM
willrok13's Avatar
I purchased a Stant brand cap from AutoZone the day I was going out of town and my gas cap stripped and couldn't be removed. It was like $8 and has worked without any codes since September or so of last year.
cimomd
Mar 18, 2015 11:18 AM
rovernoob
Jul 9, 2014 12:12 PM
GAK
Aug 11, 2010 06:16 AM
jakerr
Mar 9, 2010 05:46 PM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
