Another coolant leak for you guys
Old Mar 4, 2013 | 04:24 PM
sDot's Avatar
Default Another coolant leak for you guys
I have a 99 DII and the center climate control squeaks every so often, and I have also been noticing that coolant leaks a tiny bit. I believe it seems to be coming from the back passenger side area perhaps. I just had to replace my ypipe because it corroded so I am not sure if that ever had anything to do with it, but after spending a little bit of cash I would like to try and stop this leak pretty cheap.
My oil doesn't look like milkshake, I don't have oil in my coolant, and i'm not getting any misfires or engine codes.
Any ideas?
Old Mar 5, 2013 | 01:00 AM
rent/borrow a coolant pressure tester from parts store. Pump up to 15 PSI and let truck sit, say 30 minutes, and look for leak.
Old Mar 10, 2013 | 09:20 PM
sDot's Avatar
I see some leakage at the intake manifold where the tubes plug in from the coolant tank..
Old Mar 10, 2013 | 09:22 PM
sDot's Avatar
Actually I guess it's the Throttle Body Heater Plate?
ZMonet
Jun 24, 2016 04:00 PM
Ghaniba
May 14, 2015 07:23 AM
calebbo
Oct 12, 2011 09:54 PM
tastandish
Jul 3, 2009 03:11 PM
MRDM1
Mar 16, 2007 07:03 PM
