Another D2 No Start
Old Jul 6, 2012 | 10:43 AM
thecarfarm's Avatar
M&S will only flash after I crank for about 5 seconds. They do not flash during cranking. It is a frustrating gremlin issue at this point.
Old Jul 6, 2012 | 10:45 AM
Go test the voltage of your battery as it sits.
Old Jul 6, 2012 | 11:36 AM
drowssap's Avatar
sounds like your battery is going to fail a load test
Old Jul 6, 2012 | 12:57 PM
during the act of cranking many things inhibit to make more power available to starter
Old Jul 6, 2012 | 02:57 PM
thecarfarm's Avatar
So my ASE certified mechanic buddy dropped by with a Solus OBDII reader, here are the codes we are getting:
108 Supply of Voltage Continuous
39 EWS Multiplication Check
107 ECU Power Supply
170 A/C Compressor Control
236 CAN Time Out AGS/EGS
The Solus is also showing 0.0 as a voltage readout for the battery.
The battery is a fairly new Die Hard Gold and is fully charged. Put it on the trickle charge this morning and it showed full charge. It has been holding charge no problem and the truck is spinning over strong with no problems.
Still a battery issue or am I having ground problems? It is odd since all the grounds look excellent and I've had much crustier trucks run fine with more ground corrosion then I am seeing here.
Old Jul 6, 2012 | 03:12 PM
thecarfarm's Avatar
OK...new update...swapped out the R6 and R9 engine management relays...now it starts and dies right out. New codes after this tinkering showed:
168 Idle Speed Actuator Closed
169 Idle Speed Actuator Open
131 Rough Road Impluse
Trying to see if Solus has "Quickfix" available.
And yes, we are using the Rover keys and software for the Solus.
The plot thickens...
Old Jul 8, 2012 | 11:15 AM
thecarfarm's Avatar
Any more thoughts anyone?
Old Oct 20, 2012 | 02:23 PM
bink1109's Avatar
Any updates to this issue?
Old Oct 26, 2012 | 08:51 AM
thecarfarm's Avatar
Ended up swapping out the engine control relay from another truck and it started.
Madness.
MAN "O" WAR
Mar 12, 2014 09:27 AM
caymandrew
May 2, 2013 06:25 PM
armyeng
Mar 8, 2011 05:58 PM
Hyakku
Sep 17, 2010 08:49 PM
JAC
Oct 2, 2009 09:41 AM
