Another Day, Another Busted tool on a rusted nut..
Old May 2, 2013 | 05:04 PM
caymandrew's Avatar
Default Another Day, Another Busted tool on a rusted nut..
My anti sway bar link assembly on the right hand side is shot. I'm trying to replace it but the nut is seized on the thread pretty good. Because it's already trashed I should be abler to get a vice grip on the back side? Has anyone else run into this?
Old May 2, 2013 | 05:10 PM
ZGPhoto's Avatar
Wait, did you break tension on the nut(have it spin freely) before inserting the t40 torx in there?
Old May 2, 2013 | 05:22 PM
caymandrew's Avatar
I think I follow you. I first put a socket on the nut, and it turned easily, I then realized that the nut and shaft were both spin freely as one entity. I then inserted the torx and attempted to remove nut from shaft with the ratchet. Ergo, broken torx. What am I missing?
Old May 2, 2013 | 05:34 PM
ZGPhoto's Avatar
Okay good haha, because that's what I did by mistake at first(tried to twist wrong way with torx).
Basically what I ended up doing(besides soaking the thing with PB blaster to death) is get a wrench on there, insert the torx in it with a socket, get the socket wrench lodged against the axle housing, and twist with the wrench, not the torx socket. Sorry if I explained that like a 6 year old.
Old May 2, 2013 | 06:25 PM
Roustabout's Avatar
From what I remember, I cut mine off with a zip disc from the opposite side of the mount from where your wrench is.
Charlie_V
Feb 14, 2014 02:16 PM
jeff spahn
Apr 19, 2012 04:22 PM
Jimmy Salsa
Feb 7, 2012 09:01 PM
calebbo
Oct 20, 2011 10:07 AM
kjordan
Feb 20, 2010 04:38 PM
