Anyone see this? Oil filter adapter for mounting pressure gauge.
Old Feb 1, 2010 | 08:26 AM
meltdowndave's Avatar
Just installed this over the weekend.
I had an initial issue with oil seepage. I'm not sure if it was because I overtorqued the o-ring or something else. I removed it, placed a thin bead of "The Right Stuff" gasket maker on the outside of the o-ring and then replaced using less torque.
So far so good.
The downside that I see is that there is not enough clearance between the oil filter and the splash pan. I had to leave out the rear pax side bolt fastening screw. Some cutting with a Dremmel might be in order to free up some space and get that bolt back in place.
Old Feb 1, 2010 | 08:32 AM
lipadj46's Avatar
Get rid of the splash pan. Pretty neat gadget, does it do pressure and temp?
Old Feb 1, 2010 | 04:20 PM
It has 3 ports. So one of each plus a spare if you want redundancy.
plasticjesus
Feb 11, 2013 09:24 AM
Chris-bob
Mar 15, 2012 07:02 AM
bcameron70
Aug 23, 2011 09:14 PM
aemnky606
May 23, 2010 06:06 PM
