Is the Autel AL619 the proper scanner to buy ?
Old Dec 27, 2025 | 07:46 PM
Externet's Avatar
The Foxwell site says it is not for 2000 - 2003 ---> https://www.foxwelldiag.com/pages/coverage-checker
Old Dec 27, 2025 | 07:54 PM
PickleRick's Avatar
I highly doubt there's a huge difference on the abs systems from 1999-2004(ours is a 1999)
Before I found frayed wires under our abs module I was resetting a random abs light every few months. Then again when a passenger side hub decided to yeet itself. Found it thanks to the scanner, it was tight but not enough to stick out when spinning the tire on a jack stand and had no side/side play.
Old Dec 28, 2025 | 05:20 PM
PickleRick's Avatar
Had to use the abs feature again tonight on the foxwell when the 3 amigos randomly appeared.
Will not work while running. Key must be on position, not running. Tried it while the significant other was driving to the store.
Random open valve fault I've never seen before.
Old Jan 15, 2026 | 01:10 AM
HopeItsNotAMoneyPit's Avatar
Originally Posted by Niohdachi
I have this Autel based on an older post I saw on a forum. It IS able to read the ABS codes
I concur. I've been using this Autel model for 5 years and it DOES indeed check ABS codes on my 2003 Disco. However, it does not read ABS codes on newer vehicles. I can't recall the exact cutoff but I think it is 2018.
Old Jan 17, 2026 | 04:16 PM
disco96sd's Avatar
How does it do on D1's ?
Old Feb 5, 2026 | 09:29 PM
Pureckleyp's Avatar
6th Gear
Great advice on the Autel AL619! Having the right scanner makes all the difference when you're dealing with issues on the Discovery II. For anyone who often needs to send diagnostic reports or repair documents, I’d suggest giving https://comfax.com/fax-without-fax-machine/ can you send a fax without a fax machine a try. It's an app that lets you send faxes and documents straight from your phone, which is super convenient when you're on the go and don’t have access to a fax machine
thanks for the information!
disco96sd
May 24, 2025 09:38 AM
littlelady
Dec 1, 2010 09:50 PM
Soccer Dad
Jun 10, 2010 09:57 PM
jrm123180
Apr 7, 2010 09:24 AM
Chris on Maui
Nov 27, 2009 08:19 PM
