auxiliary fan replacement question
Old May 13, 2019 | 06:54 PM
dealbergaria11's Avatar
Default auxiliary fan replacement question
Is it easy to replace the auxiliary fan? I do not have very much mechanical experience at all. Ive started to some of the stuff myself like the regular maintenance and fan clutch? I haven't found any goo videos on how to replace it, are there any out there?
Old May 14, 2019 | 06:51 AM
WaltNYC's Avatar
Are you referring to the electric fans in front of the A/C condenser?
Old May 14, 2019 | 06:53 AM
Saturnine's Avatar
That is the only aux fan on a disco so probably
Old May 14, 2019 | 07:08 AM
CollieRover's Avatar
I would say this is very easy. You have to take off the grill, but that is not a big deal.
There is a way to swap just the fan motor, and you should be able to find a thread with a part number, etc.
Old May 14, 2019 | 07:54 AM
ahab's Avatar
It's a fairly easy job and pretty self explanatory when you remove the grill, a copy of the RAVE manual will help. There are a couple cross bars which are 13mm, and you'll need a 1/4" drive 10mm socket with a ratchet and possibly a swivel, also some pliers to remove the clips for the wiring loom. A 10mm ratcheting box-end wrench helps immensely for a couple of the bolts. Your biggest obstacle will likely be corrosion on the bolts themselves so some PB Blaster is recommended, and I like to reassemble with Never-Seize. As CR points out, it may be easier to simply replace the motor in situ but I haven't gone that route yet myself.
Old May 14, 2019 | 09:05 AM
shanechevelle's Avatar
Why are you replacing it?
sayeedA
Sep 8, 2017 06:56 AM
zuke
Jul 4, 2017 06:28 PM
bbaileyii
Sep 27, 2013 09:08 AM
dpaller
Jun 21, 2013 08:17 AM
Eak69
Apr 6, 2010 04:50 PM
