Avoiding the dreaded Drive Shaft Issue
Old Apr 11, 2019 | 02:51 PM
DISCOFETA's Avatar
Default Avoiding the dreaded Drive Shaft Issue
What is the actual problem with the driveshaft issue that the D2's are infamous for at high miles? I only have 70k on mine... But I was doind the 60K service and I am unsure about the grease the axel and driveshaft step. Then I see this issue where they can "explode"
Someone fill me in!
Old Apr 11, 2019 | 02:52 PM
NewToTheTwo's Avatar
https://www.google.com/search?q=disc...hrome&ie=UTF-8
Old Apr 11, 2019 | 03:01 PM
CollieRover's Avatar
You’ll hear a whistling and a close visual inspection of the u joints will be conclusive.
Old Apr 11, 2019 | 03:08 PM
Bumble's Avatar
From what I've read, the problem is compounded by the fact that the A/C drain drips directly onto the joint which further cooks it. The PO of my 2002 D2 rerouted that line so it doesn't land on the U-joint.
Old Apr 11, 2019 | 03:25 PM
MichalNY's Avatar
The U joint on your front shaft is not servicable(you cant grease it). Over time it seizes, casing the shaft to break. Freely rotating joint cracks your transmission case further compounding the damage
Someone fill me in!
Old Apr 11, 2019 | 04:56 PM
Best4x4's Avatar
Yep replace with any aftermarket unit with zerk fittings on all the U-Joints.
Old Apr 13, 2019 | 03:25 AM
DavidOHendo's Avatar
Banned
Sorry to chime in but visuals not good enough. You have to remove it for the best inspection.
Old Apr 16, 2019 | 07:49 PM
stb616's Avatar
So you have a rover with 70k on it....pretty rare club to be that low of miles. Buy a new shaft, spend 20 minutes to replace it and don't worry about the problem.
Old Apr 17, 2019 | 03:18 PM
Motorhead1's Avatar
The problem with the design is the front drive shaft resides right next to one of the catalytic convertors, the heat cooks the grease. I grease my u-joints every 3-4k, I usually get three pumps of grease in before they pop. Don't go over 25k without having the centering ball serviced.
Old Apr 17, 2019 | 06:42 PM
Extinct's Avatar
You can also take it out and replace the u-joint with a greasable one, tools at O'reilly, parts less than $15.
cimomd
Sep 23, 2017 04:54 PM
Crash458
Aug 18, 2014 12:09 PM
pauldavidanthony
Feb 17, 2013 07:57 AM
TripleThreat
Jun 26, 2011 01:33 PM
jhewitt1111
Jan 25, 2011 09:55 PM
