Battery light coming on dash, possible alternater failer?
Old Jul 21, 2017 | 01:57 PM
mln01's Avatar
Originally Posted by BS50MGSXR
so looks like i need to take the shroud off, fan off, loosen belt and remove it. then just disconnect the alternator? of course there is disconnecting the batter first all together. Any fun stuff i need to know about this job before the part shows up and i dig into this?
No need to remove the fan in order to get the belt off the pulleys. Just put a 15 mm wrench with a cheater bar on the tensioner pulley bolt and rotate it clockwise. That removes the tension on the belt and you can slip it off the pulley.
Old Jul 21, 2017 | 04:01 PM
BS50MGSXR's Avatar
anyone happen to know what the nut size is for fastening that braided line tite to the fire wall again?
will make a trip to home depot for the right size nut.
Old Jul 21, 2017 | 06:02 PM
number9's Avatar
While that's true it opens up more space to work in and makes reinstalling the belt easier. For those experienced with the easy on/off fan techniques it will likely add under 5 minutes to job.
Per the nut thread size? 10mm socket fits mine.
Old Jul 28, 2017 | 10:28 PM
BS50MGSXR's Avatar
New Ebay alternator on, things worked great on the test run to the lake. Although I did mess up the small wire going to the alternator. Tighten the nut down and bent the metal connector thingy that holds the nut in place. hopefully it stays. Kinda a pain working around the radiator hoses and the fan, but like others said, just work with everything still on and was able to get the belt off too with the fan in place.
DiscoRover007
Dec 9, 2011 08:46 PM
lkarraker
Apr 10, 2011 10:17 PM
phill5409
Sep 24, 2008 05:38 PM
mr.47
Dec 4, 2006 02:48 PM
arrkerr
Dec 14, 2005 10:06 AM
