Battery light coming on dash, possible alternater failer?
Originally Posted by BS50MGSXR
so looks like i need to take the shroud off, fan off, loosen belt and remove it. then just disconnect the alternator? of course there is disconnecting the batter first all together. Any fun stuff i need to know about this job before the part shows up and i dig into this?
No need to remove the fan in order to get the belt off the pulleys.
Per the nut thread size? 10mm socket fits mine.
New Ebay alternator on, things worked great on the test run to the lake. Although I did mess up the small wire going to the alternator. Tighten the nut down and bent the metal connector thingy that holds the nut in place. hopefully it stays. Kinda a pain working around the radiator hoses and the fan, but like others said, just work with everything still on and was able to get the belt off too with the fan in place.
DiscoRover007
Dec 9, 2011 08:46 PM
lkarraker
Apr 10, 2011 10:17 PM
arrkerr
Dec 14, 2005 10:06 AM
