Battery Tender connection to battery
Old Jan 10, 2021 | 12:32 AM
SeanBaker's Avatar
Default Battery Tender connection to battery
I have to think this is probably a stupid question. I want to connect this Battery Tender cable to my D2 battery. There's a screw on the positive battery cable I can use, but there's nothing on the negative side. Just the nut that is used to tighten the battery cable, and I don't think I want to use that. I have a plain battery that doesn't have any accessory terminals.
What's a good way to add something so I can attach the ring terminal to the negative side? Do I need to change the battery cable terminals?
Thanks in advance,
Sean.
Old Jan 10, 2021 | 12:41 AM
SeanBaker's Avatar
Or do I just need to connect the negative to a ground point somewhere?
Old Jan 10, 2021 | 06:47 AM
Hysteria's Avatar
Any ground point will work
Old Jan 10, 2021 | 07:55 AM
The Deputy's Avatar
Yes, right outside of the battery box...there's a small terminal, which actually grounds right off negative cable...just attach ground there.
Old Jan 10, 2021 | 01:18 PM
SeanBaker's Avatar
Wow, can't believe I didn't see that, works perfectly, thanks! Here's my connections:
I routed the connector through the side and over the headlight cover, and zip tied it to the battery:
It doesn't interfere with the battery cover. I can attach my extension easily and still close the hood if I want.
My D2 can sit for a while. Not cool when you want to drive it and the battery doesn't have the oomph to start. And I don't want to find out what it's like to not be able to unlock it.
Next on the list is to get a small extension so I can get to the connector from the grill. Then I shouldn't get locked out.
Any pointers on routing the cable to the grill are appreciated!
Old Jan 10, 2021 | 01:44 PM
The Deputy's Avatar
Nice clean install, great job!
Old Jan 17, 2021 | 12:03 PM
SeanBaker's Avatar
Default Update
I bought this
extension cable extension cable
so I could hook up the battery tender through the grill.
I rerouted the terminal connector to the side of the battery and connected the extension:
I put some black tape on the connection just in case, and zip tied the end caps to hold them in place:
Tucked the cables to the side of the battery and routed the extension to the front:
I routed the extension around the horn so it wouldn't flop around:
I made sure to get an extension cable with end caps to protect from the elements, and I use the cap to to attach it to the grill:
Now I can attach the battery tender without opening the hood, and I can tuck it into the hood in case of rain:
It's a simple thing, but was fun to do and makes it super easy to keep my battery charged and ready to go!
Thanks,
Sean.
Old Jan 17, 2021 | 02:27 PM
mr. choodles's Avatar
That's a great mod!
Old Jan 18, 2021 | 11:45 PM
nashvegas's Avatar
I have one of these on an old motorcycle... good idea to add to the seldomly-driven Disco. Love it right thru the grille.
LADisco2
Nov 15, 2016 03:48 PM
aemnky606
Nov 12, 2016 11:38 AM
oilspotLR
Aug 21, 2012 09:55 AM
yarddawg
Jan 15, 2008 07:40 PM
DG62
Aug 15, 2006 11:18 AM
