Belt tensioner noise?
Old Feb 13, 2013 | 07:12 PM
MC04DII's Avatar
Default Belt tensioner noise?
Every now and then I hear a loud squeel up there, and when I listen under the hood it sounds like fast rattling right around the tensioner. Sounds like small pieces of gravel (or bearings). Also, I can move it side to side about a mm. I just did a water pump change and shortly after I started hearing it. I obviously had to fool with it to get the belt on and off for the water pump. Is this what they do when going bad?
Old Feb 13, 2013 | 07:15 PM
You need to replace that pulley before it fail and you loose a bely. I would also suggest you check the other 2 pulleys also.
Old Feb 13, 2013 | 07:19 PM
MC04DII's Avatar
I wouldn't mind loosing some of my belly, nor would my wife , but just to confirm that is normal when they are at the fail point?
Old Feb 13, 2013 | 07:31 PM
MC04DII's Avatar
Well, just ordered a tensioner and idler pulley kit (all 3) for $152 shipped from AB. Just when you think she's running well...
Old Feb 13, 2013 | 08:46 PM
dr. mordo's Avatar
Tell me about it - I've had tensioner problems on three vehicles this winter.
Spike555
Jan 21, 2008 05:19 PM
DeepBlueWater
Nov 11, 2007 01:21 PM
SnakeLogic
Dec 2, 2006 05:14 AM
evoasis
Nov 4, 2006 07:58 PM
esaycho
Oct 12, 2005 03:24 PM
