Benefits of using premium gas?
Old Jul 11, 2007 | 07:06 PM
bdud98disco's Avatar
Default Benefits of using premium gas?
I have a 98 disco and ive been using 87 and probably should be using premium what effects has using 87 done to my car and what differences will occur when I go to 91?
Old Jul 11, 2007 | 07:49 PM
howardstapley's Avatar
Default RE: Benefits of using premium gas?
91 burns slower at a high flash rateand is for high compression engines. Using lower octane gas, depending on the compression of the engine(newbie to Discos so I don't know the spec's yet) could be minimal or you could be scorching everything from your block, pistons, valves, exhaust ports on your heads, exhaust manifold and O2 sensor not to mention filling your cat with soot faster. Again, I am moreaccustom to Corvettes and BMWs as they were my past cars but that was the case with them and most likely the long term result for Discos.
My 2c
Old Jul 11, 2007 | 08:02 PM
SpeedAgent's Avatar
Same here regarding BMWs, but you are spot on. Underperformance is the least of your worries if you consistently use an octane rating less than recommended. Once or twice if you can't find 91+ is fine, but not all the time. It could cost you considerable sums later on.
Russratt
Sep 16, 2014 08:31 PM
me 2
Apr 2, 2013 09:27 AM
humroot
Mar 21, 2008 01:55 PM
pblake4
Feb 7, 2008 07:21 AM
