Best mothod for removing stubborn gasket and sealant material
Old May 29, 2014 | 11:27 AM
MarkSF's Avatar
Two suggestions :
1) You can get plastic razor blades for this purpose.
2) A carbide scraper. You pull it, instead of pushing it, which makes it less likely to gouge deep scratches.
Old May 29, 2014 | 03:45 PM
OffroadFrance's Avatar
I've just read online that gasoline or lighter fluid dissolves RTV successfully. I used both cellulose thinners and brake cleaner with some limited success. Unfortunately it seems whatever one uses it still remains a lot of boring hard work to finally clean it all off. RTV is great stuff provided it used where it's easy to remove later and used sparingly. (I over used it on the rocker cover gasket out of frustration to stop the oil leaks on the Pajero )
Old May 29, 2014 | 03:51 PM
evansjoem's Avatar
Plastic putty knifes
Old May 30, 2014 | 09:23 AM
SuperSport's Avatar
I used to grind the end of a good flat file at a slight angle. Need to be very careful on aluminum as mentioned to prevent gouging.
Old May 31, 2014 | 12:41 AM
jfall's Avatar
Carb cleaner.
Spray the crap out of it.
Comes right off with STP carb cleaner from the auto parts store.
Wear gloves though.
Stuff will poison you and is probably the cause of toxic waste dumps.
SO be careful.
mln01
Feb 5, 2015 09:59 PM
gbob
Jun 14, 2013 02:52 PM
ngarover
Apr 16, 2012 09:48 PM
calebbo
Dec 12, 2011 09:40 PM
kenk
Jun 10, 2011 08:45 AM
