Black rtv on oil pump cover?
Old Aug 7, 2024 | 11:24 PM
evil_goat's Avatar
Question Black rtv on oil pump cover?
I have seen some videos that use rtv and some that dont on the oil pump cover. My gasket looks like this
Should I use the rtv on both sides of the gasket?
I also got some of this for the bolt threads
https://www.autozone.com/sealants-gl..._0?spps.s=6277
this will work, right?
Old Aug 8, 2024 | 07:14 AM
WaltNYC's Avatar
Workshop manual (12-2-41) specifically says dry. See attached page.
If you don't already have the workshop manual you can find it in the google drive linked in my signature in the D2 section.
File Type: pdf
Old Aug 8, 2024 | 09:58 AM
sqlbullet's Avatar
Manual says dry....but I have always put Permatex form-a-gasket No. 2, the non-hardening version, on paper gaskets.
Old Aug 8, 2024 | 03:51 PM
zski128's Avatar
I know it says dry but I did put a very thin coating on each side of the gasket. No issues after 10k miles.
Old Aug 8, 2024 | 05:55 PM
evil_goat's Avatar
Do I need to use rtv on the oil pan? I have a rubberey feeling gasket for that?
Old Aug 8, 2024 | 06:23 PM
zski128's Avatar
Check the RAVE, you need to blobs right where the front cover meets the block. The key to keeping the oil pan from leaking is following the bolt sequence in the RAVE not over tightening them.
Old Aug 9, 2024 | 08:07 AM
WaltNYC's Avatar
RAVE is your friend. You are doing a pretty large and technical job. Better to read up in advance than have to tear into it again.
neuropathy
Aug 18, 2022 01:46 AM
ttownthomas
May 5, 2020 07:34 PM
MaineDisco2
Nov 6, 2016 11:50 PM
fosterjd79
Mar 7, 2016 06:00 AM
Charlie_V
Feb 15, 2015 07:01 PM
