Block pressure test? psi?
Old Jan 26, 2016 | 10:34 AM
Hephaestus's Avatar
Originally Posted by drowssap
im a little confused, I thought you said you found the leak at 20 psi? where was the leak?
Ah, I should of clarified. I "found" the answer to my psi question-20psi. Did not find any leaks and even went a little higher just to make sure. Thinking block is ok. I will post some photos later. You had me thinking about rebuilding the bottom end too. Tempting.
Old Jan 26, 2016 | 10:40 AM
drowssap's Avatar
i misunderstood I thought you found a leak in the block at 20 psi, my mistake.
well if the block is ok then the c2o had to either a leaking head gasket or possibly a crack in a head.
have the shop check the head when they will them, if they don't find anything then it would have had to be a head gasket
Old Jan 28, 2016 | 11:05 AM
Hephaestus's Avatar
Here are some photos of the pressure test setup I made. Talking to the machine shop they test heads at 60psi. I think I should check the block again.
Notice the carbon cleaning on the heads. The piston tops have an even coating of carbon. Anyone good at reading these? Blow by?
Old Jan 28, 2016 | 11:31 AM
drowssap's Avatar
nice simple setup.
one question for you could you have left the water pump on, and just looped the intake and discharge hoses?
Old Jan 28, 2016 | 11:41 AM
Hephaestus's Avatar
You mean the discharge hose on the intake? I did fasten some rubber over the pump inlet with a hose clamp and it slowly inflated then exploded. I decided to check out the impeller on the pump anyway so I just took it off and made a template.
Old Jan 28, 2016 | 11:53 AM
Hephaestus's Avatar
Only one hose left with the heads and intake off.
Old Jan 28, 2016 | 12:00 PM
drowssap's Avatar
just figured that out
humroot
Jul 22, 2019 06:33 PM
knightmetro
Feb 27, 2014 10:35 AM
Savannah Buzz
Jul 11, 2011 05:54 PM
0304Disco
Mar 24, 2011 02:55 PM
meltdowndave
Jan 30, 2010 06:56 PM
