blown factory subs...help
Old Feb 20, 2009 | 02:45 PM
  #21
Rover Chris's Avatar
I grew up in an Anheuser-Busch town (Merrimack,NH) so it was either that or one of the micro-brews that the old retired AB brew masters would have at the local micro breweries.
Old Feb 20, 2009 | 05:37 PM
  #22
Frank4's Avatar
I just switched mine with Pioneer TS-A1702C. It is separate 2-way set, I just didn't bother with the tweeters. It was a tight fit but I managed to get the door unit back together. They sound pretty good, just don't expect super low rattling bass. They are 4 ohm 230 watt max and come with small mountable amps. Best Buy has them for $150 a set. Hope this helps.
Old Feb 20, 2009 | 05:44 PM
  #23
actually those are crossovers not amps, and the speakers are not subs they are mid range drivers
Old Feb 20, 2009 | 08:25 PM
  #24
Frank4's Avatar
The box and directions refer to them as amplifiers, but thanks for the tip.
Old Feb 20, 2009 | 09:40 PM
  #25
HA HA, thats funny I just looked at a picture of the crossover online and it really does say amplifier on it, and this is why I wouldn't buy anything from Pioneer!!! I wonder if they do this cause people will buy it cause it will sound "amplified"!!!
the crossover network actually says amplifier at the top because thats the side that will connect to the amp (at least thats what I gather from the pic I saw), Frank4 if you have the crossover installed I would actually remove it because that amp channel is already filtered and you are actually taking away from the signal by using it.
I shouldn't badmouth Pioneer they make great products and nobody should think otherwise just because I wouldn't buy from them. I just disagree with some of there tactics is all.
christiansmith6
Aug 18, 2014 12:37 AM
badbowtie85
Jul 3, 2007 04:53 PM
Captain Ducman
May 30, 2007 05:40 PM
thesearch35
Audio/Visual Electronics
Apr 25, 2007 09:59 PM
Captain Ducman
Dec 4, 2006 09:13 PM
