brake bleed...
Old Feb 6, 2009 | 11:03 PM
sharp's Avatar
Default brake bleed...
is the engine running or off while performing a brake bleed?
Old Feb 6, 2009 | 11:10 PM
llPANCHOll's Avatar
Default RE: brake bleed...
Off...
But as I understand it, between each wheel you should stand on the brake pedal for a period of time (30 seconds or so) in order to cycle the fluid out of the ABS...
I would assume that the vehicle should be on during this part of the process.. But no Bleed Screws open ANYWHERE.
I did not try this ABS Fluid Cycling deal.. and my bleed turned out great.. No problems what so ever..
Perhaps someone could weigh in on this..
Old Feb 7, 2009 | 10:00 AM
Off unless you have a D2 and are trying to push some of the old fluid from it's system.
JavaDiscoII
May 29, 2010 04:33 PM
old gold
Dec 3, 2008 10:28 AM
mwyrick45
Feb 7, 2008 11:24 AM
ste
Mar 23, 2007 06:47 PM
flyingalexf68
May 9, 2006 01:51 PM
