Brake Bleed Order
Old Aug 18, 2013 | 01:37 PM
jh.'s Avatar
jh.
Default Brake Bleed Order
I've always bled brakes RR, RL, FR, FL (just like it's mentioned in https://landroverforums.com/forum/di...stalled-33785/ - which is why I'm doing them again).
However I just noticed in the RAVE (page 70-31) that for LHD Discos, it should go FR, FL, RR, RL.
Which is correct?
Also, since I'm replacing all 6 brake lines, I was planning on one line, one wheel at a time (i.e. remove the FR wheel, replace the FR line, bleed the FR, move on to FL ~ where I would also change the 2 small lines) - is this correct or should I replace all 6 lines and THEN do a bleed?
Old Aug 18, 2013 | 02:13 PM
You are right, but bleed make sure you bleed each caliper until you get clear fluid thru each, in the case of the r/r, it might take 7 or 8 times and plan on 2 quarts of DOT to do it. Make sure to empty the old fluid from the m/c and refill with new before starting.
Old Aug 18, 2013 | 02:18 PM
jh.'s Avatar
jh.
So do the bleed counter intuitively and I can replace the lines one at a time and bleed following each line?
I'm also using this as an excuse to paint my wheels, so one at a time works great for me if advisable. If I have to replace all brake lines first, I will - but it would be better for my particular situation to do them as I get the wheel off to paint...
Old Aug 18, 2013 | 02:36 PM
You replace all the lines at once then start bleeding.
Old Aug 18, 2013 | 03:51 PM
jh.'s Avatar
jh.
Damn. OK. Thanks for the help!
Old Aug 18, 2013 | 04:36 PM
potxoli's Avatar
Is it really that critical to change all the lines first? Due to limitations of my driveway (slight slope), getting the car lifted on 4 jack stands is not something I'm happy about. How about split the difference and front axel first and then rear?
Old Aug 18, 2013 | 05:02 PM
Sure it is cause every time you remove a line you pretty much have to re-bleed the entire system so why not do them all at once, saves time and fluid.
chicane
Apr 5, 2014 08:04 PM
JavaDiscoII
May 29, 2010 04:33 PM
mx930
Dec 30, 2008 08:08 PM
ste
Mar 23, 2007 06:47 PM
flyingalexf68
May 9, 2006 01:51 PM
