Brake Caliper Guide Pin Stuck
Old Mar 17, 2015 | 07:32 AM
drowssap's Avatar
i have one i have to do tonight after work, hoping heating it will be enough to get it out
Old Mar 17, 2015 | 01:29 PM
CBRacerX's Avatar
Originally Posted by CBRacerX
I just had this same issue. I was not able to find the carrier cheaply, $80 on this side of the pond was the cheapest. So I cut off the end of the pin that protruded from the carrier, clamped the carrier in a small drill press, center punched the pin that was stuck and started drilling with small bits up to large. I was able to finally get the old pin out only after drilling to almost 100% of the brass insert size. But I got it done and once my new pins arrive I will reinstall the front brakes with a lot of high temp grease on the sliders!
As an update, I got the new pins today and installed in the "drilled out" carrier without incident. Brakes working great again.
ImQuattro
May 1, 2014 08:36 PM
Shark59
May 4, 2013 09:33 PM
TRIARII
Dec 17, 2012 07:51 AM
Fitzpatrick
Feb 17, 2011 09:09 PM
