Brakes
Old Feb 12, 2009 | 04:09 AM
Tvdmtac's Avatar
Default Brakes
Question should I replace all the ABS sensors when I repalce the rotars and pads etc. on a 2000 Disco II?
Thomas
Old Feb 12, 2009 | 08:38 AM
okdiscoguy's Avatar
Default RE: Brakes
It isn't necessary. If you still have an ABS fault, have someone with a rover scanner read the codes. They are about $100 a piece, and you onle need to replace them if they go bad.
Old Feb 12, 2009 | 06:36 PM
roverguy7's Avatar
Default RE: Brakes
its a pain and you need to be able to do some wiring if you replace them. the sensor design has been updated and now is wired directly to the ecu, no connector two feet away anymore... and yeah, there is no reason to replace them unless they go bad, and to tell you the truth, they really dont go bad too often, just a bad connection, hence the new style sensor
Old Feb 12, 2009 | 08:14 PM
Tvdmtac's Avatar
Default RE: Brakes
Thanks for the reply's everyone!
Thomas
Old Feb 12, 2009 | 11:13 PM
avking's Avatar
Default RE: Brakes
I just cleaned mine when I did rotors and pads. Liberal amount of brake cleaner.
Old Feb 13, 2009 | 09:03 PM
Do your self a huge favor and let sleeping dogs lie, you will have plenty of opportunity to fight with the ABS when it is acting up in the future.
FightOnUSC79
Nov 26, 2010 09:43 AM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
BigMike
Mar 30, 2006 09:45 PM
bakerww
Jan 30, 2005 10:36 PM
