Brakes
Old Jul 5, 2007 | 07:15 PM
99discoII's Avatar
Default Brakes
I recently had my brakes done 60 days agoon my 99 Disc II. However they don't seem as sensitive as they were. There seems to be alot of pressure from the begining and I really have topush hard if I want it to stop fast. I have been in cars were there is no pressurethis is not the case here. The pressure doesn't match theslow stopping. Is there something they can adjust or did something go wrong. I have 4 wheel disc brakes ABS.
Thanks
Old Jul 5, 2007 | 07:33 PM
acousticrawk's Avatar
4th Gear
Default RE: Brakes
did you have just the pads replaced? or pads and rotos together? if it was just pads, did you have the rotors machined? if not your brakes will be spongey for some time because the pads and rotors dont match. they should both be replaced at the same time or the rotors should be machined, if not, thean thats where the soft pedal comes from. from there i would try a system bleed. brakes use a hydrolic fluid that over time breaks down and looses it ability to hold pressure as well, or even you mave have by a fluke got an air bubble into your system. good luck, hope thats a start.
Old Jul 5, 2007 | 08:07 PM
SpeedAgent's Avatar
Default RE: Brakes
It's either that or they need to be properly bed-in. You can find info on that procedure anywhere online.
FightOnUSC79
Nov 26, 2010 09:43 AM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
BigMike
Mar 30, 2006 09:45 PM
bakerww
Jan 30, 2005 10:36 PM
