brakes
brakes
When I hit the brakes hard on a rough road the pedal practically goes to the floor.
I have learned that if I tap the brakes once on a rough surface and then apply pressure it is not an issue.
Ibelieve this is an issue with the antilock brakes, because I can feel the pulsation of the brakes that is unrelated to the road surface, but can not find a solution.
Any suggestions?
Any suggestions?
RE: brakes
2004, 52000 miles, Brake fluid had not been changed unless it was part of the usual scheduled maintenance. The brake pads were replaced at the dealership less than a year ago, with I assume standard LR parts.
I mentioned it when the pads were replaced, but this particular dealership has ignored other questions and requests.
RE: brakes
Well, does the vehicle stop?? That should be the main question.
Secondly, mine does the same thing, and I just assume it is the ABS keeping the vehicle from skidding... if you let go of the brake for a split second, and push it down again, you should feel a definite difference in the braking distance and force. That's what I've been doing..
Hopefully this sparks some convo.
John-Robert :]
John-Robert :]
