brakes
Old Nov 6, 2007 | 07:40 PM
cbrantner's Avatar
Default brakes
When I hit the brakes hard on a rough road the pedal practically goes to the floor.
I have learned that if I tap the brakes once on a rough surface and then apply pressure it is not an issue.
Ibelieve this is an issue with the antilock brakes, because I can feel the pulsation of the brakes that is unrelated to the road surface, but can not find a solution.
Any suggestions?
Old Nov 6, 2007 | 07:59 PM
Default RE: brakes
What year, how many miles, have you ever changed your brake fluid and what brake pads and rotors are you running?
Old Nov 7, 2007 | 12:19 PM
cbrantner's Avatar
Default RE: brakes
2004, 52000 miles, Brake fluid had not been changed unless it was part of the usual scheduled maintenance. The brake pads were replaced at the dealership less than a year ago, with I assume standard LR parts.
I mentioned it when the pads were replaced, but this particular dealership has ignored other questions and requests.
Old Nov 7, 2007 | 12:29 PM
meyersd's Avatar
Default RE: brakes
That's your first problem, you are taking your truck to the stealer.
Old Nov 7, 2007 | 02:41 PM
hobiecat's Avatar
Default RE: brakes
You may want to try and bleed the brakes. If it is catching after a pump of the pedal you may be pushing fluid to the calipers and then the second pump put enough fluid to the caliper.
Old Nov 7, 2007 | 03:09 PM
johnnybob06's Avatar
Default RE: brakes
Well, does the vehicle stop?? That should be the main question.
Secondly, mine does the same thing, and I just assume it is the ABS keeping the vehicle from skidding... if you let go of the brake for a split second, and push it down again, you should feel a definite difference in the braking distance and force. That's what I've been doing..
Hopefully this sparks some convo.
John-Robert :]
Old Nov 7, 2007 | 05:33 PM
Default RE: brakes
Partially normal and some of it can be corrected with a full brake flush. I would buy 2 quarts of Vavoline's synthetic brake fluid and spend 1/2 an hour and do a complete bleed.
FightOnUSC79
Nov 26, 2010 09:43 AM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
BigMike
Mar 30, 2006 09:45 PM
bakerww
Jan 30, 2005 10:36 PM
