Brakes, Help
Old Jun 30, 2016 | 09:10 PM
haasri's Avatar
Default Brakes, Help
New to me disco2 2003, purchased and told it needed new brakes as well as other things. Since brakes are an important part of driving I changed those first, rotors good bearings good calipers were free of binding. Bled brakes traditional way LF,RF,LR,RR. Pedal still not good tried again same result. Tried hill holder method along with bleed no good. Changed master cylinder repeated all efforts and still no good. I have not changed the brake lines as I didn't see any swelling or leaks. Any direction would be greatly appreciated.
Old Jun 30, 2016 | 09:14 PM
mx468's Avatar
I thought you did the rr, lr, fr, fl, thats how how I did mine.
Old Jun 30, 2016 | 09:17 PM
haasri's Avatar
That's how American cars do it the RAVE says different. Don't really know. I always thought you worked from the wheel farthest from the master cylinder.
Old Jun 30, 2016 | 09:23 PM
haasri's Avatar
Default brakes
Ok looked at RAVE again, bled the brakes per right hand drive not left hand drive, I guess I'll try again tomorrow. Put brakes on 2 other vehicles this week and didn't have this much trouble even with changing calipers.
Old Jul 1, 2016 | 12:48 AM
Fallstaff's Avatar
Welcome to Land Rover!
Old Jul 1, 2016 | 06:38 AM
drowssap's Avatar
You are correct Rr Lr Rf Lf.
Old Jul 1, 2016 | 09:47 AM
jafir's Avatar
Bleed at the lines coming into the modulator. Then bleed at the lines coming out of the modulator. Then bleed at the wheels according to the sequence in RAVE. That is what got a good firm pedal on my 2003 after I had the modulator out to fix the shuttle valve switches.
FightOnUSC79
Nov 26, 2010 09:43 AM
amvauto
Sep 18, 2008 07:38 PM
1eyescooter
Feb 1, 2007 11:12 AM
1eyescooter
Jan 15, 2007 08:48 PM
Rover9
Sep 19, 2006 04:17 PM
