Brakes are locking up
Old Jul 19, 2011 | 04:47 PM
Billmrshll's Avatar
Default Brakes are locking up
I have an '99 Disco 2 with 150k on it. Yesterday, the brake pedal began getting higher an higher through a 10 mile drive. Eventually the brake pedal was all the way to the top and the brakes were dragging. I had to pull over because the brakes were dragging so bad. They would not release so I was pissed and left it there. Went back this morning and the brakes were fine and as I neared the house it seemed like it was happening again.
Any advice? Thanks a ton.
Old Jul 19, 2011 | 04:52 PM
When was the last time you flushed the brake system? Sounds like maybe a failing master cylinder.
Old Jul 19, 2011 | 05:13 PM
Billmrshll's Avatar
Default never
I've never flushed it out. Is there a repair kit or is the normal operating procedure to just buy a new master cylinder?
troy24
May 18, 2013 09:14 PM
Tony Crosland
Oct 5, 2012 02:44 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
johanba
Apr 3, 2007 11:37 AM
