brakes making loud squeeling/ a knock
Have the codes read at the dealer. I would suggest an indy mechanic over the dealer. Just need to find one with a Rover-comatible scanner that can read and clear the codes. Some dealers will not clear the codes unless they do work on it to fix it.
Squeaking brakes will set off the lights. Neglected repeated warnings will mess up the system and set a hard fault. It was resetting on its own before. Now it is a hard code and has to have a comuter to reset it.
just to let everyone know. there is another landrover shop here in nashville that is made up of all ex landrover employees. they told me they got tired of landrovers shenanigans and high prices. so they all left and started their owns shop, and its jsut as big as the dealers...after i had the breaks replaced and new rotors. the lights were still on. so i took it to this shop, they ran the codes and said that it was an intermittent signal from the rear right abs sensor. they cleared my codes and everything works like normal now. and that was over a week ago.
