brakes making loud squeeling/ a knock
Old Jun 7, 2010 | 11:28 AM
have your brake fluid flushed, then you will need to go to the dealer to have the lights turned off.
Old Jun 7, 2010 | 03:08 PM
okdiscoguy's Avatar
Have the codes read at the dealer. I would suggest an indy mechanic over the dealer. Just need to find one with a Rover-comatible scanner that can read and clear the codes. Some dealers will not clear the codes unless they do work on it to fix it.
Squeaking brakes will set off the lights. Neglected repeated warnings will mess up the system and set a hard fault. It was resetting on its own before. Now it is a hard code and has to have a comuter to reset it.
Old Jun 24, 2010 | 07:44 AM
David Simmonds's Avatar
just to let everyone know. there is another landrover shop here in nashville that is made up of all ex landrover employees. they told me they got tired of landrovers shenanigans and high prices. so they all left and started their owns shop, and its jsut as big as the dealers...after i had the breaks replaced and new rotors. the lights were still on. so i took it to this shop, they ran the codes and said that it was an intermittent signal from the rear right abs sensor. they cleared my codes and everything works like normal now. and that was over a week ago.
Profitsx
Oct 22, 2014 03:28 PM
velija
Apr 14, 2014 04:08 PM
tibyABv6
May 16, 2010 11:35 PM
stick
Jan 27, 2008 01:29 PM
DV57
Dec 17, 2007 02:15 PM
