Bypassing the HK factory amp
Old Oct 24, 2011 | 09:51 PM
Snafu / Disco Fries's Avatar
Default Bypassing the HK factory amp
I had put a new sound system in months ago and it is fantastic. Only issue is I get the buzz from the alternator due to the ground loop that is created between this system and the factory amp. I could wire in some group loop interrupters, but that is actually more of a pain than usual and you can lose some clarity that way. So, the easiest thing I think would be to just bypass the factory amp under the driver's seat. Anyone attempt this? The new head unit has plenty of power without needing a separate amp anyway. Before I go cutting wires, would love to see what others have done (or other suggestions to get the buzz out of it).
Old Oct 24, 2011 | 10:18 PM
see attached from RAVE.
Not sure if you could treat leads E2 and F2 from the amp, or just what connector they appear on.
File Type: pdf
File Type: pdf
Old Oct 24, 2011 | 10:36 PM
I was looking at that before and wondering if I could cut and splice those wires. It looks fairly straightforward in the diagram, but I know I'm missing something! Thanks as always Buzz
Madlands
Jul 23, 2014 06:47 PM
JohnKimble
Sep 17, 2013 12:13 AM
me 2
Audio/Visual Electronics
Jul 2, 2012 04:48 PM
Snafu / Disco Fries
Apr 29, 2012 06:38 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
