A/C is cold and fan is running on high, but not much air coming through the vents
Old Oct 13, 2016 | 04:45 PM
bcolins's Avatar
Default A/C is cold and fan is running on high, but not much air coming through the vents
Thinking that the doors and flaps that control where the air flow goes are either electric or vacuum servo actuated and that I have one not working. Very little air flow through any of the mid dash level AC vents with the fan on high.
Suggestions?
Brian in Austin
Old Oct 14, 2016 | 09:49 PM
bcolins's Avatar
anyone else experienced this?
Old Oct 15, 2016 | 11:30 AM
back9sunday's Avatar
I have! Yes! I throw my blower motor on max speed and I can only feel a fraction of what I feel with the rear vents. Just a run-down of what is going on in my Disco and may be the same in yours,
Front Head level Vents Compromised
Front Foot level vents not compromised
Any of the rear vents not compromised
It's been like that ever since I bought the Disco, but never got around to doing anything about since I thought it involved taking the fascia off.
Would love to get some more input on this. Thanks
Old Oct 15, 2016 | 03:13 PM
OffroadFrance's Avatar
It sounds like either the A/C - heater clack flaps are stuck or the foam seal has blocked the airflow. I assume you have run the full cycle of A/C direction options via the control buttons? Turn the mid and rear cab A/C to off and hopefully the additional air pressure may release the front flaps OK albeit the rear is a completely separate system apart from the A/C gas.
Old Oct 16, 2016 | 01:23 AM
bcolins's Avatar
No rear air on this one.
Old Oct 16, 2016 | 01:25 AM
bcolins's Avatar
I can hear something like a piece of paper flapping around when I turn the system on,......dont know where one would get in,......Anyone know if there is access to any areas where there might be a piece of papper trapped??
Old Oct 16, 2016 | 11:40 AM
Red5's Avatar
Remove the fiberboard cover between the globe box and the firewall, it's secured with a few plastic anchors. Then you will see the housing for the blower. There are 3 bolts to remove and the blower will drop down.
The paper may be trapped in the squirrel cage. Also, with the blower removed you should have access to a few of the flaps. You can check for damage/blockage.
Old Oct 16, 2016 | 12:03 PM
bcolins's Avatar
Thanks, Ill check it out.
Old Oct 20, 2016 | 05:53 PM
Fallstaff's Avatar
With my old jeep it was a mouse's nest. Spent a few years filtering the air past his dried up corpse before I figured that one out…
Old Oct 31, 2017 | 08:14 PM
bcolins's Avatar
Default Fan was full of leaves
Well what sounded like paper was actually the squirrel cage being completely full of small live oak leaves. Much more air flow now with the AC on, but still blows partially through all the vents all the time.
Bsnow
Jan 27, 2012 10:48 PM
Miwo
May 4, 2011 08:40 AM
Eak69
Apr 4, 2010 11:52 AM
VikingDiesel
May 22, 2009 07:34 PM
