Cam and crank settings v8 01 disco II
When crank # 1 cylinder is at uppermost position, and cam shaft gear mark is at 600. If the two marks are where they are supposed to be, can the timing still be off in relationship to the intake and exhaust valves opening. Hope this question is understandable, hard to explain what I am thinking. Just installed new cam. Want to make sure there isnt a valve orientation other then the gear marks lining up.
Thanks Mrg
Thanks Mrg
mouse
05-18-2012 12:25 AM
