Camshaft Removal Question
Does the 4.0L Disco2 engine need to be pulled out of its engine bay in order to remove/replace its camshaft?
I'm assuming that it does but I don't cuz I've never done it etc...
Thanks,
Thomas
Thanks,
Thomas
Like BUNDU said.
Removing the radiator is a must. You can keep the A/C lines attached to the condenser. Just lift and rotate out of the way...the lines will give enough for this but be gentle when doing it.
