Can these plugs used for measuring transmission temperature?
Old Oct 15, 2019 | 12:52 PM
Discorama's Avatar
I linked the Arduino stuff just to share the technical background on how to connect a sensor to Torque Pro.
The actual product is much different. It is just a small box which goes into the engine compartment and requires installation and wiring of sensors, but no wiring through the firewall. And of course no C programming (forget about the details in the link), just setting up Torque pro like it's done for an ODB-Adapter.
Old Oct 15, 2019 | 07:26 PM
Extinct's Avatar
Thanks for the link, very interesting. May have a few questions, will dig in.
Old Oct 16, 2019 | 08:28 AM
Sandman614's Avatar
Does anyone know the thread of the radiator/cooler temp switch? Also does anyone have a diagram of the fluid flow?
Old Oct 16, 2019 | 07:15 PM
Extinct's Avatar
I will check the threads, I have a couple old radiators that have not gone to the trash yet. The rave should have a coolant flow diagram, or are you talking about the trans flow?
Old Oct 16, 2019 | 07:37 PM
Discorama's Avatar
If you look for the temp sensor on the coolant radiator, it is M12x1.5.
Old Oct 16, 2019 | 09:52 PM
Sandman614's Avatar
Trans flow, but I don't think it's very important. I think I'm going to put in 2 temp senders, one in the cooler (I'm guessing that's the hot side) and one on the trans at the suction port which is next to the cooler return.
Old Oct 20, 2019 | 12:59 PM
Sandman614's Avatar
Originally Posted by Discorama
Probably I found the answer to my question. The ports in question are the pump's suction and pressure ports (what they are there for is a different question).
More info here: https://manuals.hgmelectronics.com/c...re_Sensor.html
So it looks like you can even measure the transmission fluid pressure. I wonder why would one measure it. At least I will try to use the suction port for temperature measurement. I got a VDO temp sensor (NTC, M14x1.5) and the workshop manual says it is an M14 bolt, I hope that fits.
The Pump suction and Line pressure plugs are 3/4(19mm) head and the threads measure 19.7mm indicating by this chart it's a M20 thread. I didn't think to measure the inner diameter to see what the thread pitch is but it is looks to be fine pitch.
I want to do more research on the T/C and 'A' clutch lines before using one of those ports which look to be closer to m14, they are 6mm allen keyed.
I may have misunderstood which thread you were referring to but the Transmission cooler Temp Switch thread is M10x1.
https://www.checkfluid.com/pages.php?pID=20&CDpath=3_20
Old Oct 20, 2019 | 03:34 PM
Discorama's Avatar
Thanks, good to know. Probably M20x1.5, since it is most common. Have you figured out the flow? Do you know at what port the fluid is present before it goes to the radiator? I assume it is the pressure port.
For the T/C I installed an M14x1.5 sensor (red dot) already. There was a bolt in it, no sensor:
Old Oct 21, 2019 | 07:51 AM
Sandman614's Avatar
I think this is confirmed, at least for the 4hp22, based on this parts list.
https://www.4x4community.co.za/forum...=1571661862798
back9sunday
Aug 8, 2016 10:43 AM
willo
Sep 13, 2015 10:37 AM
collin Barrows
Aug 8, 2011 09:33 PM
lipadj46
Oct 17, 2010 06:34 PM
Mark G
Sep 26, 2007 06:49 PM
