Can you listen to this and LMK if I have bad lifters?
Cold start, specifically listen to the tap tap tap after I put it in D to drive away (around 26 seconds). Exhaust leaks are all sorted and it sounds loads better, so the only thing I'm left with is possible bad lifters? Or is this just normal clattery Disco noise?
Ignore the whiny PS pump. Another one is going in this week.
Oil pressure normal. Water temp ~188.
Mine sounds exactly like this when cold, but I think my fixed exhaust leak is still leaking a little bit. When it warms up however, I get a different ticking which is definitely internal. Replaced the lifters, pushrods, rocker arms, timing chain and no difference in noise.
